It should be easier to replace than the antiquated one on the UCE models too, though in the UK at least it looks like it might get covered in road filth unless a fender extender is fitted. I've fitted one on just about every new bike I've bought in the last 10 years at least, except the C5 which is the only model I know, apart from the B5, that has fully valanced mudguards (fenders). Let's hope the oil filter is a standard size too; I'm fed up of buying a different filter removal tool every time I change bikes. At least when Wildbill changes his bikes he can keep his toolkit, at least for the most part....
Presumably also the service intervals will be more in keeping with modern practice. I can't see why they shouldn't be as the engine is a completely modern design and the days of hand building them have gone. The new R&D centre in Leicestershire, near the Hinckley Triumph factory, is state-of-the-art having CAD, 3D printing, dynes and all the other kit you'd expect to see in a modern design centre. The way I see it anything from the twins onward should be pretty good for the type of bike. I don't think the Himalayan was designed here so that might be more of a lottery. Whatever, I'll definitely test them all come late spring.
