Author Topic: Oil leak  (Read 6999 times)
TWinOKC
Reply #15 on: November 19, 2012, 10:12:45 pm
Just my 2 cents,
If you are overfull, it is easier (for me) to draw off the excess oil using an inexpensive hand held transfer pump than it is to pull the drain plug.
You can get a transfer pump at Harbor Freight for about $4.00  They are very handy to have around the garage.
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Reply #16 on: November 19, 2012, 10:17:26 pm
I can't get nuthin' right today!
LarsBloodbeard
Reply #17 on: November 19, 2012, 11:10:42 pm
Just my 2 cents,
I wonder if a turkey baster would work for that too...
Reply #18 on: November 19, 2012, 11:40:47 pm
Sure it would.  Just add a short length of vinyl hose to the tip and suck away! :)
I suppose your significant other would want the baster to be washed out sometime before cooking the turkey although I think any oil that costs over $44 per gallon would probably give the bird a little something extra!
I can just hear it now,
"What did you do with this Turkey?  It's simply heavenly! "
"I really shouldn't but, do you mind if I have another piece? " ;D
Reply #19 on: November 20, 2012, 01:49:19 pm
This may be stupid, but how do you accomplish this?  I tried to get a number of different small flexible tubes down into the sump from the oil fill opening, but I couldn't manage it.  There was just too much mechanical junk in the way.  What am I missing?
gremlin
Reply #20 on: November 20, 2012, 03:24:17 pm
.......There was just too much mechanical junk in the way.  What am I missing?
evidently nothing !    :P
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Lwt Big Cheese
  • Getting there, slowly...
Reply #21 on: November 20, 2012, 03:26:13 pm
A) Remove petrol tank.
B) Remove battery.
C) Invert motorcycle.
 :o
No warranty implied or given.
May contain nuts.
