OK Guys
Today I pulled out the old coil, replaced it, the coil wire to the plug, a new plug, cleaned the carb, battery charged, new air filter, gas in the tank, kill switch has never been used and was disconnected 20 years ago(never quite figured out a need for that thing), all wiring looks good, I dipped the tip of the plug in petrol and still...no go.
The plug I now have in there is from India, Mico/Bosch W145 Z 1. Will new-in-a-box plugs go bad over time? But I have now tried three different ones. I tried attaching the pic of it but I don't see that it did indeed attach to this post. It is a short threaded plug and one I got at a shop/dealer, I guess.
Ammeter doesn't move a mm. Even if the ammeter is bad, and I am thinking it is not, the bike should still start, no?
Lights work, horn works and when I flip on the lights, the ammeter lights up too.
Tomorrow I will pull off the headlight and tackle anything in there that might look suss but the ammeter is connected properly. I will also see if I have a new set of points and a condenser. If not, where can I get a set quickly? India takes weeks on ebay.
It's all my own fault as I had it up and running well last summer after I got my strength back from covid but I haven't ridden it in maybe 7-8 months,,,not even cranked it as I was too, well lazy/procrastinating/busy working. And, it is kept outside under a cover here in Florida.
As we all know, these beasts need to be running to stay running well.
Worse to worst, I will have it towed to a mechanic but that grinds me since, up to now, I have done all the work on this thing myself. Plus the cost of a mechanic.
I know it is probably something aggravatingly simple, but what could it be?
Also, if anyone knows how I can get the two carb gaskets quickly, That would be appreciated. The one on the float bowl and the 'diamond' - shaped one sealing the air flow from the filter box.
Thank you all
Mitchell
