Author Topic: What is this deadend wire in headlight ?  (Read 9608 times)
on: June 06, 2011, 06:35:36 pm
There is a grey colored wire behind the headlight, in the nacelle of my G5 that went nowhere - just deadend.  What is this for ?
Okie Enfield
  • RED 2010 C5
Reply #1 on: June 06, 2011, 09:43:58 pm
 ;D I-POD port  ;D
jjoe256
Reply #2 on: June 06, 2011, 09:56:37 pm
It may be a wire for a parking light.
JesterNT
  • Maintenance is as much art as it is science.
Reply #3 on: June 06, 2011, 09:57:22 pm
Does it have a voltage +/- ?
Quando Omni Flunkus Moritati
Reply #4 on: June 06, 2011, 10:13:53 pm
Singh, did you check the wiring diagram in the owner's manual?
Reply #5 on: June 06, 2011, 10:58:06 pm
I'll bet it's for the little parking light that used to be in the headlamp, I wonder if the Indian domestic models still have it?
drbvac
  • Low as it can go
Reply #6 on: June 06, 2011, 11:24:58 pm
The other gray wires in the headlamp go to the pilot lights so the parking idea is probably correct
Dr B
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Reply #7 on: June 07, 2011, 12:17:16 am
Its the flux capacitance inducer
GSS
Reply #8 on: June 07, 2011, 03:51:17 am
I think you are right. My C5 came with the 7" Minda headlight and the little parking light and this might be it..........
« Last Edit: June 07, 2011, 12:45:18 pm by GSS »
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
2bikebill
Reply #9 on: June 07, 2011, 08:23:48 am
+1 for the parking light. UK bikes have 7" headlight with a little parking bulb in the side of the reflector.
Reply #10 on: June 07, 2011, 12:50:16 pm
You mean my G5 is missing a parking bulb  :D !
Nah, I like the idea it is an I-pod line  ;D - Now, I will have to buy an I-pod/pad - those touch thingy's.  They are amazing though.
Thanks to all.
« Last Edit: June 07, 2011, 02:47:46 pm by singhg5 »
Sub
  • Bob's Your Uncle
Reply #11 on: June 07, 2011, 03:14:22 pm
Ohhh, so if that is a switched 12v+  power line, that would be PERFECT place to tap off for my forthcoming headed grips! :) I wonder if it has its own fuse.
Andy
Reply #12 on: June 07, 2011, 03:35:23 pm
Another one of those little mysteries - like why the switch for four-way hazards isn't connected.
2010 C5 Military - "The Slug"
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #13 on: June 07, 2011, 06:01:46 pm
What switch? Pic?
drbvac
  • Low as it can go
Reply #14 on: June 07, 2011, 08:36:45 pm
I believe its between the starter button and the stop engin button on the right handgrip.
I put on a Kuryakin rig to hold the throttle in postition while cruising to give my hand a rest so it doesnt fall asleep and was concerned about covering the switch. Then I realized it didnt connect to anythign so who cares ::)
Dr B
