Reply #17 on: February 21, 2020, 08:40:45 pm
I can see why you had problems with the brakes.
Frank
The cam levers are fairly advanced on the front. And the rear may look about half wore out. Is that what you are seeing , Frank? Anyhoo, good effort ddavidd, you saved another Bullet Original from the scrap heap.
Logged
