You are right, I just checked it and the rear wheel seems not to be aligned properly :-(
Apparently I need to have a serious word with my garage - it was just in for inspection 500 km ago.
Where can I find the torque for the rear axle - the manual provided with the bike just refers to "use the right torque..." :-(
regards
Toni
A bike shop will just line the axle up with the alignment marks... which only works if they're accurate. There's a good chance they aren't, and not because RE are roughly built. Over the years, I've had two bikes that had inaccurate alignment marks, both were Japanese and one was a GSXR-1100, a bike where it really mattered.
The easiest way to check alignment is to 'string line it' - ie, you use a piece of string. There should be plenty of youtube videos, but choose an easy one, I've seen a few that just make it too much like hard work. Some people love to over complicate things.
I'm not sure how zimmemr does it by eye, but I'm quite sure it can be done, if only as a quick check to see if you've got a problem or not.
