Greetings from the North-east region of India.
I'm new to the forum as a member, but I've lurked around all you knowledgeable folks, and have learnt a great deal. Including....
"search the forum before you post a query". Relax, I only jest, as that is sound advice.
Now, to come to my issues, with the motorcycle, that is. I would like to apologise to everyone for this wall of text
(yes, we have the Colonial legacy of the Queen's English here). RE here isn't being helpful, and seem to send me around in circles.
Engine: Weird ticking noise from the left side of the engine (sometimes from the right as well). The noise seems to be loudest around the rocker/head covers, and is not present all the time. It comes up loud enough to hear while riding at 3000rpms, doesn't change rhythm with throttle, happens randomly on a cold or a warm engine. It's a distinct ticking noise, like that of the second hand of a clock.
RE service can't help me any further (they've said so much to me). Valves and clearances, nuts and bolts have been torqued down and cam chain tensions have been checked. RE says the noise would die down by the time I hit 6000Kms on the odo. I have ridden more than 6k now, and the noise is still here. RE also says they don't want to open up the engine unless necessary, and this noise is a non-point for them. I checked their test-ride sample, and that one, doesn't have the noise- they checked mine after this...and did some things they wouldn't tell me, sound reduced, wasn't gone completely, and now it's back.
Front end: Braking induces a soft knocking sound. I've read elsewhere on this forum, that this is quite common, and that it could be due to forks not being topped off with fork-oil consistently. RE here said, that this noise comes because of the floating disc up front
Additionally, I also get a knocking noise accompanied with a slight rattle when I go over gravel-y roads or cobblestoned paths, or similarly rough surfaces.
Rear end: A strange noise that feels like something is loose and rattling. I can even feel it in my footpegs. It only happens when I go over gravel-y roads, cobblestones, dirt-pack roads and such. Point is, noise only happens when going over minor bumps and rattling broken roads. Never when going over big bumps where the suspension travels significantly. I also put in a piece of foam under the seat to narrow down the source of the sound, as the seat can rattle. However, after numerous attempts, and fixes, the noise is still, there, and riding feels like parts are going to fall off.
Dear lord of all that is beautiful.....how many times have I raised this issue with RE...only to be met with
"I can't gear any abnormal noise", or my favs of-
"yeah there's a noise, but it's there on every one of these bikes"; and
"yeah this is because of the shocks. You see, new ones don't have the noise, but it comes after a few days of riding",
"You need more weight on the suspension for it to work properly, so adjust preload, and it'll go away"These suggestions don't make much sense to me.
Please HELP!
