Hi. It's not the stock carb. And yes, sorry it's the needle jet at 106. Yes, I stripped the carb again & cleaned the slide. It was better but still misbehaving. So I drained the tank, fresh fuel & cleaned the tap filter. And hey presto! It's even worse now🤣 rough as a bears arse, running richer & more smoke. Idle screw right in, popping & banging when you give a little throttle. What's next?
