hmm. more troubles today. or disappointment rather.
I rode to the nearby church to borrow their parking lot while nobody was around (its the only large paved area out where I live).
I parked the bike with the valve stem as close to bottom dead center as I could and marked the pavement with chalk.
I hopped on the bike started it up and rode slowly with all my weight on the bike counting the tire rotation...1...2...3.
parked the bike with the stem as close to BDC as I could and marked with chalk.
pulled out the measuring tape. 234 inches. divided by 3 thats 78 inches.
perfect I thought.
converted to mm for a grand total of 1981.2mm
I thought, thats awful small compared to the figures of 2068 or whatever y'all were giving me.
so I did it again. 4 full rotations this time.
came up within 1mm of the same number.
must be correct.
take off to ride the bike back home.
I'm screaming at 4k rpms in 5th gear and my speedo says 55mph. not a lot of throttle left either. odd... usually with the old factory speedo it would be reading around 65mph right now.
I give it full throttle, pushing it to its limit. it slowly creeps up 56, 57, ... 60mph absolute top speed. probably burning around 4.5k+ rpms in 5th at this point.
"No", I tell myself, "I know these bikes are pretty freaking slow, but the old gauge I topped out multiple times before at 70-75mph. I always cruise 60-65mph on the backroads home from work and have a solid 1/4 throttle left to give. This can't be correct."
So I ride back to the church and do the test for a 3rd time. 233inches. thats 77.7in. thats 1973.6mm roughly
so I plug that number in.
a little better, 55mph cruising speed, still a slow climb to 60mph though. honestly not much different than it was before. maybe gained 2mph or so but thats it.
bike was fully warmed up, conditions were good. I don't know why it reads slower than the oem gauge was. I was using the digital mph readout as I have the needle doing tach, but I can't imagine they'd be different. But ill try tomorrow and see. maybe the old gauge was just off some. id be curious to have a friend drive next to me and see how fast his car says were going. When I went on that long ride with my buddies we had a guy in a newer Audi RS7 behind me the whole way. I asked how fast we were going, and he said usually around 55mph. so maybe its not off. my other buddy leading the pack said we were doing about 65 at another point in the day when I was keeping up with them, but he also said his speedo was probably off some.
and ive always heard the old "55 all day, 65 for awhile" saying with these bikes, but that was for the old 4 speed iron barrels. I figured the 5 speed AVL lean burn here would be capable of more like "60 all day, 70 for awhile". And thats how it seemed with the oem gauge. so now im confused on what's correct. its only 5mph, but still.
Thinking the math must be correct. perhaps ill go back another day and try for about 10 rotations or something see if I get the same numbers.
OR maybe its just not tuned to its peak performance. By that I mean, I have things running a hair on the rich side (I think, thats a whole other story) with my BSA exhaust, hot tube mod, and up jetting the bs29. my chain probably has a hair too much slack in it too, but thats honestly negligible. everything else is in perfect working order though.
Also I may very well switch to an 18 tooth sprocket at some point. try and bump that top end up just a bit. if I could maintain 65mph on this bike id be a happy camper.
