Welcome aboard, @linestunter. Congrats on the new bike! Seems like you're one of many sportbike riders who've seen the light and found out how much fun going back to basic can be! I've never owned a "fast" bike (my fastest was a TRX850 but apparently they're not very quick) and my 535 CGT is perfect for me. I love it.
The single cylinder grunt is pretty fun, huh? It's cool plonking along and only changing gears when you feel like it.
When you do the oil change, take it super easy on the drain bolts. I know you've done lots of spannering but these are different. The main drain bolt, the big one: Do it up finger tight, then give it a couple of bumps on the spanner to just nip it up. A lot of these guys have stripped the thread out of their case doing it up to torque spec. The smaller plug seems less prone to stripping. Don't be frightened by all the metal shavings caught in the oil strainer (next to the drain bolt) but also, take it easy on those cheesy screws that hold it in. I don't bother to check it every oil change anymore, maybe every 3rd change will do me. The 3 filter cover screws too. just nip them up.
I've taken it easy on all the screws on my bike and haven't stripped or snapped one yet, touch wood. It doesn't leak oil and no plugs or screws have vibrated out.
I see Sparesbox (online) has Penrite MC-4ST 10w50 and HPR Diesel 15w50 on sale 20% off with free delivery for 20 litre drums right now. That's not bad.
You a control line flyer by any chance? That's fun, too.
hi yes many moons ago, still have a fox 35 and some hand oilers around , were great times as a boy
have got the oil change done ok , no stripped bolts, i replaced the copper sump plug washers with fiber washers as they seal better and need less toque to seal, i just nibbed them up so alls good
the filter screen had some metal shards and what looked like fiber dirt so glad i did an early oil change
will do another oil change and clean the screen at 500k mark and see what the screens like, if the screens clean will leave it alone on next change
when i fitted the sports gold star muffler i also fitted a straight through header pipe removing the catalytic converter so have no worries running zinc in the oil
not really sure the engine needs it as it has a roller cam roller lifters but i guess if zincs anti wear it carnt hurt
i think the joso spec is for clutches in motorbikes, but plenty people running motor car or diesel oil without any problems
i have watched some Indians doing bullet 500 oil changes on youtube dumping the oil then starting the engines not once but twice to pump out the last drop of oil , unbelievable no way would i do that
cheers damien
