So I ended up removing the shim we had under the needle.
Feels better coming out of 1st from a stop now.
Also accelerates noticeably faster through midrange (as expected)
Top speed has also increased by about 4mph (unexpectedly because the main jet is still the 118, granted its about 20 degrees colder today too)
The header however continues to turn all sorts or purple and blue and gold...
Im starting to question having the larger main jet...
everything is stock on this bike except for deleting the PAV system and pulling that baffle out of the header.... so im wondering if a larger jet is even necessary after removing the baffle in the header pipe?
perhaps it is and ive just gone too large with it? The spark plug doesnt appear to be too rich. in fact it almost looks like im somehow running both too rich and too lean??? just guessing by the super white ceramic, but then the "a little too black" sooty ring around the base here...
I also notice the ground strap is burned a little more than halfway back so this plug might be a bit hot. supposedly its an equivalent to the B9ES NGK (I ruined that NGK when I put the 118 in it and it was super rich, hence why I pulled the baffle out, then put this autolite plug in and it seemed happy but still slightly rich, hence removing the shim we had on the needle now).
So idk im thinking I should just put the 110 back in but now im not sure with the baffle removed if that'll be too lean... maybe like a 115 would be better? I need to order a jet kit...
at any rate, this running slightly rich and at higher rpms for long periods of time is the only thing I can think of why my pipes are turning color, but I mean they are super BLUE.
