On a 500 Electra X I tuned in 2008 for Hitchcocks as a basis for a tuning kit, I tested 32, 34 and 36 mm carbs on the dyno, one after the other, on the same day. Each increase in size gave an overall increase in power, throughout the rev range, with no porting work done to the head, as requested due to the proposed kit having to be of the 'bolt on' variety.
Our own RE 500 'Big Head' racer runs on methanol and wears a 38 mm MK2 Amal carb, fitted with a rather rare twin float, float chamber and while running on the dyno, we have sometimes had issues at certain higher RPM's, where the floats have been overcome by vibrations, causing the carb to flood, although it is difficult to know for sure if this happens while out on the track. We have had some random, strange fueling issues with this machine on occasion, so perhaps it can rear its head during a race from time to time.
I don't think Asbo 44 would need to ever go much past 7,000 RPM to give its best - I was both surprised and pleased to see it get to 7,000 RPM while still pulling well!
B.W.
