Yes it should be a blue wire with a white stripe that sends the wheel speed signal to the instrument cluster.
The 3 wire speed signal, usually will have a positive feed, a ground / negative feed and a speed signal output.
Have a look through the documentation of your new speedometer, the GT535 speed sensor will most likely need to be calibrated to your digital speedometer and you would also need to know the circumference of the tyre.
