I have a 22 int650 and have been changing the taillight and signals to Baak. Tested everything and each signal worked as did taillight. Went for final steps to electrical tape the junctions and nothing works front or back for indicators.
Taillight is fine.
Fuses are fine.
Swapped back to stock relay from hitchcocks and nothing.
No front or back at all.
Any advice is great… other than “it’s under warranty” as this is aftermarket stuff.
Again, work fine for each independent step then everything went foul.
