Hi All,
Troubleshooting a 2007 RE 500 Bullet Electric Start I have just recommissioned and serviced.
Firstly the bike starts and runs fine however intermittently the Starter relay would not activate, when this scenario happens the Ammeter reads negative "before pressing start button", with no buzz or click at Solenoid/Relay. Before you say bad relay/solenoid below is the troubleshooting I have done eliminating the Relay/Solenoid.
New fully charged battery, 12.8V not running, I have followed the Start Button circuit through handlebar Kill Switch/Starter Button/headlight connectors/coil/Points etc and have confirmed this issue only happens when the points are closed, I can unplug Relay/Solenoid and even before pressing the start button I see low voltage of 10.1V. The power supply to the Starter solenoid "Red White Wire" and "Blue White Wire" only receive 10v and wont activate starter Relay/Solenoid....... However if I Manually open the points or just kick the engine around to where the points are open I will see the ammeter go from negative to zero and measure 12.8V at the Relay/Solenoid...... I can then press start button and Electric start then activates and bike starts no problems.
Seems the power circuit for the starter relay shares with the Coil/Points on this bike, is that normal? is it just a RE Quirk or is something wrong here, loom all looks factory. I'm not 100% sure but I would think its normal for Coil/Points circuit to dip voltage prior to sparking like what I see here, so why is the Starter Circuit shared with this?
PS When I see the 10V at Coil and Solenoid/Relay I can measure 12+ direct at the battery so it is just this circuit with the voltage dip.
Cheers
