What's the "top fill mark"?
My filler neck has no marks.
Overfilling is a bad thing..(charcoal canister)
I fill with the bike on the side stand, and only until the fuel contacts (barely) the BOTTOM of the neck.
If I run low on fuel, we have these things around here called "Gas stations" where they will put more fuel into the tank for you.
If you're crossing the Gobi desert or the like, that extra 2 ounces of fuel isn't going to make much of a difference!
Cookie
Topped off my '21 Interceptor today after 155 miles. I always fill to the top fill mark on the filler neck, shake the bike a bit to remove any air bubbles. Used 2.1 US gallons to reach the mark. 74 miles per gallon. Not unusual for this bike, lately. I ride easily, cruise at no more than 3600 rpm (60 mph) and acceleration rarely sees above 4000 rpm. Gas today in Central Texas was $2.63/gallon. Throttle response indicates no evidence of an overly lean mixture.
Are others getting this sort of fuel economy? Bike has 5200 miles since I bought it new, just 2 years ago.
Ralph
