Yeah so I have upgraded to the 7in headlamp already, and I am running a brighter H4 bulb I got from the parts store, it’s still halogen though, iirc it’s 55w low and 60w high beam. I also have led turn signals. Yeah originally the 7in headlamp being deeper just hit the speedo cable, He’s claims it’s likely my rubber around the speedo being deteriorated or backwards but it’s on correctly and in good shape. I ended up using a flat style connector from my Honda bike and it was still a tight fit but it fits. I also had to move wiring to the side and use some zip ties to keep it held to the side while installing the new lamp. But it’s not like rubbing or pinched or anything like that.
But what’s curious is it did this before even when all the lighting was stock. In fact it’s never worked right since I got the bike. It’s definitely not just a “that’s how old halogen bike lights are” thing, the low beam is way brighter, the bright might as well be a child’s night light on the wall in terms of lumen output.
I mean the low beam sucks too, but it’s putting out enough light that I go “well that’s just how old bikes usually are” granted I use the same bulb in my wife’s piaggio scooter and it’s WAY brighter. That could be the reflector design of the headlamp or something though I guess.
No weird resistors or anything in line, just a electronic flasher relay for the led turn signals is all I’ve changed, but that shouldn’t have any effect on the headlamp, and the rest is still all factory wiring.
I’ll check the resistance on the switch then.
