Recieved this ad in my e-mail:
https://www.bsacompany.co.uk/bsa-gold-star/Gold Star: A design icon of its era, redefined to reclaim its glory in the current times, the new BSA Gold Star’s design is a befitting evolution of our most successful motorcycle. From only £6,800...($8,500 USD?)
Gold Star Legacy Edition: A design icon of its era, redefined to reclaim its glory in the current times, the new BSA Gold Star’s design is a befitting evolution of our most successful motorcycle. From only £7,000...($8,750 USD?)
SPECIFICATION
ENGINE
Engine Type – Liquid-cooled, single- cylinder, DOHC, 4 valves, twin spark plugs
Engine Capacity – 652cc
Compression Ratio – 11.5:1
Max Torque – 55Nm@4000rpm
Max Power – 45hp@6500rpm
Transmission – 5-speed
Cooling System – Liquid
SUSPENSION
Front – 41mm telescopic forks
Rear – Twin shock absorbers with 5-step adjustable preload
WEIGHT
Dry/Wet – 198kg/213kg
WHEELS & TYRES
Front Tyre – 100/90-18 Pirelli
Phantom Sportscomp
Front Wheel – 36 wire spoke alloy rims 18 x 2.5”
Rear Tyre – 150/70-R17 Pirelli
Phantom Sportscomp
Rear Wheel – 36 wire spoke alloy rims 17 x 4.25”
BRAKES
Front – Single 320mm floating disc, Brembo twin-piston floating calliper, ABS
Back – Single 255mm disc, Brembo single-piston floating calliper, ABS
FUEL TANK
Total Capacity – 12 litres
Fuel Consumption – 70.6 mpg (WMTC)
DIMENSIONS
Wheelbase – 1,425mm
Seat Height – 780mm
Rake – 26.5 degrees
FYI:
https://www.royalenfield.com/us/en/motorcycles/int650/
Interceptor MSRP prices $5999 to $6699.
Weight 455 to 466 pounds (207 Kg. to 212 Kg.) ; 47 HP
