Author Topic: BSA  (Read 17423 times)
Richard230
Reply #120 on: July 17, 2022, 09:00:22 pm
BTW, my recollection is that my BMW (break my wallet) Funduro was a dry sump engine and had its oil stored in the frame, like my 1971 Triumph Bonneville did.
2018 16.6 kWh Zero S, 2009 BMW F650GS, 2020 KTM Duke 390, 2002 Yamaha FZ1
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #121 on: July 17, 2022, 10:45:47 pm
@ #119: Spoken like a guy that doesn't buy the "Arthritis-Size Aspirin" tubs for his knees!  ;D ;D ;D
It's a Dry Heat...
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
AzCal Retred
  • Chennai Wrencher
Reply #122 on: July 18, 2022, 07:32:34 am
https://en.wikipedia.org/wiki/BMW_F_series_single-cylinder
The BMW F650St Strada was introduced to Europe in 1993, a variant F650 (dubbed the 'Funduro') in 1994 and then to the United States in 1997.[3] The BMW F650 models were jointly designed by BMW and Aprilia, who also launched their own very similar model called the Aprilia Pegaso 650 (a 654cc single cylinder, 5 valve motorcycle).[4] The BMW version was assembled in Italy by Aprilia and these were powered by the Austrian 652cc single-cylinder, 4 valve Rotax engine.[3] It was the first BMW motorcycle with chain drive since the 1960s.[3][4] The two variant models of the F650 motorcycle had some subtle differences which determined their utility bias: the F650 'Funduro' was the more dual/multi purpose with more off-road capability due to the longer wheel base, more ground clearance and taller seat height, a higher front fairing and a larger 19inch front wheel, the F650St Strada had slightly smaller dimensions and an 18 inch front wheel. Both models used two 33 mm Mikuni carburetors.[4]
Engine   652 cc Rotax single
Top speed   F650 - 185Kmh (max rpm 8000)
F650ST Strada - 165Kmh (max rpm 7000)
Power   48hp (35kW) @ 6500rpm
Torque   39.2 lb⋅ft (53.1 N⋅m)
Transmission   5-speed, chain drive
Weight   173Kg (unladen) (dry)
191Kg (wet)
Design and technology
The F650GS had several advanced technology features for its time, with computer-controlled fuel injection,[when?] catalytic converter, a Nikasil-lined cylinder, optional ABS and an airbox designed to exploit the airflow pattern of the bike when in motion. Combined with the bike's high compression ratio and twin spark plugs (from 2004 onwards), excellent fuel economy and low emissions existed alongside high power output. The original F650 single-engine was manufactured for BMW by Austrian company Rotax while the bike was assembled by Aprilia. When the F650GS was launched,[when?] the full process was brought back in-house.
In 2000, the German motorcycle magazine Motorrad reported about a defeat device delivered within the BMW F 650 GS. BMW responded in issuing an improved injection as of 2001 and calling back the models from the previous year.[6][7]
Amongst the changes from the original F650, the engine was upgraded to a 43 mm throttle body. The fuel is stored in an under seat fuel tank,[8] and the false tank (where a conventional fuel tank would be) housed the remote oil reservoir (for the dry sump), airbox and battery. This contributed to a lower centre of gravity for improved handling.[2] The bodywork was redesigned by head BMW designer David Robb.[2]
Due to the high numbers sold, the F650GS developed a large aftermarket accessories range and a sizeable owner community. BMW also developed a large range of factory original hard luggage for the bike.
richard211
Reply #123 on: July 18, 2022, 07:43:44 am
Been going through the different F650 models and it looks like the Flywheel / Rotor for the 1995 F650 is a carburettor model. So it should be straight forward converting the EFI to carburettor.
 Ebay link of the Flywheel / Rotor
https://www.ebay.com/itm/265094050140
Richard230
Reply #124 on: July 18, 2022, 01:59:22 pm
The BMW Funduro engine was also used by MV for a short time installed in one of their sport bike chassis around 1999 or 2000. I remember seeing one for sale in the shed next to the Alice's Restaurant gas station. I seem to recall that the tachometer was redlined at 9K rpm, which caught my attention. Somewhere in my many disorganized photo albums I have a couple of pictures of the bike.
AzCal Retred
  • Chennai Wrencher
Reply #125 on: July 18, 2022, 04:47:44 pm
48ish BHP and maybe 180 Kg dry were the numbers to shoot for, I'm amazed Mahindra couldn't replicate that in 2022. Seems to me a 2nd hand $2k Funduro/Strada would give you at least a $5k modding budget. No reason to not have a DIY Goldstar, you are mostly a tank, muffler & fenders away.
We live in a carbon fiber, 3D printer future, I'm not seeing why the "Faux-star" is slower & heavier than previous efforts with this engine. At India labor rates, even hand laid up CF parts painted to look like steel would "add lightness". Lighter = more HP, better brakes for the same components.
gizzo
  • purple people
Reply #126 on: July 19, 2022, 12:45:24 am
This ^. You have it arse about face. India are more interested in cheapness than performance. They'd do the exact opposite and make a cheap heavy steel component and paint it to look like expensive carbon fibre.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
AzCal Retred
  • Chennai Wrencher
Reply #127 on: July 19, 2022, 02:08:44 am
So is there a near $4000 "contact name magic" markup going on here? If we Statesiders can get the Interceptor for about $6K, the faux Goldstar should be less, that's one of the advantages of singles, less parts, cheaper to build. The 250-350 street motorcycles that used to be twins are mostly singles now. Selling a new "nice bike" at extra-premium rates competes with the used market, awash with "nice bikes" for 1/3 to 1/5th the price. The enthusiasm for the original Goldstar was about it's superior performance for its time. It would be reasonable to expect a similar "spirited" performance level today. Using clever engineering and low-cost labor would be a reasonable way to achieve this, if that was your intent. SInce it's not happening, maybe we can expect a $4500 Fauxstar in 18 months or so to move unsold inventory.
gizzo
  • purple people
Reply #128 on: July 19, 2022, 03:03:13 am
I'd have a SR400 any day.
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
AzCal Retred
  • Chennai Wrencher
Reply #129 on: July 19, 2022, 05:37:14 am
Hmmm...27 HP, 174 Kg/384 lb. wet, 5-speed, what's not to like? Available on Craigslist from $3500, Cycle Trader From $4500 & up. They are holding value, obviously people like them.  8)
https://www.motorcyclespecs.co.za/model/yamaha/yamaha_sr400%2014.htm
GlennF
Reply #130 on: July 19, 2022, 10:38:12 am
SR400 ...
« Last Edit: July 19, 2022, 10:44:09 am by GlennF »
GlennF
Reply #131 on: July 21, 2022, 04:44:27 am
Another review - comparing the new Goldstar with a 1956 BSA Gold Star DBD34
https://www.youtube.com/watch?v=8AQWhJG14Qg
Keef Sparrow
Reply #132 on: July 21, 2022, 07:32:16 pm
My late father was once offered that model of Gold Star for £50. He turned it down. I think it would be worth rather more now....
Past: CB125-T2, T500, GT500, Speed Triple, 955i Daytona. Now: Royal Enfield Bullet Trials 500
GlennF
Reply #133 on: July 22, 2022, 12:14:02 am
Indeed, but not the insane prices people pay for a Vincent Black Shadow ...
https://motorcycles-for-sale.biz/sale.php?id=51481
https://www.bonhams.com/auctions/21135/lot/284/
https://motorcycles-for-sale.biz/sale.php?id=49708
AzCal Retred
  • Chennai Wrencher
Reply #134 on: July 28, 2022, 06:56:24 pm
Recieved this ad in my e-mail:
https://www.bsacompany.co.uk/bsa-gold-star/
Gold Star: A design icon of its era, redefined to reclaim its glory in the current times, the new BSA Gold Star’s design is a befitting evolution of our most successful motorcycle. From only £6,800...($8,500 USD?)
Gold Star Legacy Edition: A design icon of its era, redefined to reclaim its glory in the current times, the new BSA Gold Star’s design is a befitting evolution of our most successful motorcycle. From only £7,000...($8,750 USD?)
SPECIFICATION
ENGINE
Engine Type – Liquid-cooled, single- cylinder, DOHC, 4 valves, twin spark plugs
Engine Capacity – 652cc
Compression Ratio – 11.5:1
Max Torque – 55Nm@4000rpm
Max Power – 45hp@6500rpm
Transmission – 5-speed
Cooling System – Liquid
SUSPENSION
Front – 41mm telescopic forks
Rear – Twin shock absorbers with 5-step adjustable preload
WEIGHT
Dry/Wet – 198kg/213kg
WHEELS & TYRES
Front Tyre – 100/90-18 Pirelli
Phantom Sportscomp
Front Wheel – 36 wire spoke alloy rims 18 x 2.5”
Rear Tyre – 150/70-R17 Pirelli
Phantom Sportscomp
Rear Wheel – 36 wire spoke alloy rims 17 x 4.25”
BRAKES
Front – Single 320mm floating disc, Brembo twin-piston floating calliper, ABS
Back – Single 255mm disc, Brembo single-piston floating calliper, ABS
FUEL TANK
Total Capacity – 12 litres
Fuel Consumption – 70.6 mpg (WMTC)
DIMENSIONS
Wheelbase – 1,425mm
Seat Height – 780mm
Rake – 26.5 degrees
FYI:
https://www.royalenfield.com/us/en/motorcycles/int650/
Interceptor MSRP prices $5999 to $6699.
Weight 455 to 466 pounds (207 Kg. to 212 Kg.) ; 47 HP
