Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: chinoy on February 15, 2010, 04:58:59 am
Can sprockets from the older bullets be used on the UCE ?
What front sprocket options are there for the UCE front and rear ?
The UCE front sprocket is different than the older 5 speed sprocket. As far as I know there are only 2 sizes available, 17 & 18.
Not much room for anything larger in there.
The rear is not replaceable (at least on the US models) and is I believe 38 teeth.
There is a kit that will make the rear replaceable with larger sprockets but I don't know if it will fit the UCE or not.
http://store.royalenfieldusa.com/changeable-rear-wheel-sprockets
CJ
