Morning Zimmemr
Thanks for the tips. Much appreciated, I've added some points below but I'm confused I have to say. I was expecting to replace an old part like-for-like & have better results.
Without knowing the specifics, and being totally unfamiliar with the 535 I can only offer some broad hints. First, check for spark, it may be as simple as a fouled plug. With a known good plug in the engine see if it starts. If not, I'd return to the last known good set up and see if it runs, if it doesn't you know you're barking up the wrong tree and need to look at your ignition, valve adjustment, maybe even the cam timing.
- Spark is good & strong, plug is not fouled & getting wet-ish. Valves were set ok, as it ran before I changed the carb. Haven't touched the cam timing.
If it runs and you want to go back and play with the AMAL, start by setting it up to the suppliers specs for your bike. It should at least start and idle, even if it's rough. If it won't even start make sure the carb is passing fuel, the plug should be wet after a few tries if it's not passing fuel check the carb, even new ones get plugged with dirt.
- Agreed, I was expecting it to at least run! And then set it up to optimum. I've only changed the jets(which were new in the old carb) nothing else. Seems to be passing fuel ok.
I know that's a short, vague set of suggestions but without knowing your skill level, the condition of the bike etc, it's hard to come up with anything concrete. One thing I've seen is that guys get confused over which way the choke works on the AMAL, so you may want to double check that you're closing it for a cold start, and opening it for warm starts or to clear a flooded engine.
- I fell for the choke issues when I first got the bike, so that's not a root cause this time.
