Author Topic: Eureka E I / constant kickback. Related?  (Read 1667 times)
Williamsburg
on: March 26, 2020, 10:01:41 am
hello all. 76 Bullet 350, previous owner install Eureka, me, constant kickback. I've just replaced inner workings of primary case, ergo unwilling to open up again to find tdc. Need to find correct settings for Eureka and relatively cost free method of finding tdc in a language a non mechanic can understand ( eg; I don't understand 32 degrees of tdc ). If anyone understands this post and can help. It would be greatly appreciated.
Will
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #1 on: March 26, 2020, 12:35:06 pm
Welcome aboard. Did the Eureka electronic ignition work properly when you first bought the motorcycle? Electronic ignitions need a really good battery. A weak or old battery will usually cause them, especially a very cheap one like the Eureka, to run too far "advanced", which will cause kickbacks and poor running if you do get it started at all. Do you have or can you borrow or purchase an electrical multi-meter to check the battery's voltage? Multi-meters are useful and not expensive. If the battery voltage at its terminals with ignition off is below 12.5 volts after the bike has not run for several hours or more, then you may need to charge or perhaps replace the battery. Determining your battery's condition and correcting or replacing it, if necessary, should be your first step in diagnosing and solving your Bullet's problem.
I will wait until you report a voltage reading for the battery before commenting further.
« Last Edit: March 26, 2020, 12:52:33 pm by Bilgemaster »
Williamsburg
Reply #2 on: March 26, 2020, 01:50:20 pm
I wrote quick reply but it's lost. Anyway thanks another approach to tackle. I did get new battery using old as reference, 12 volts 6ah, too weak maybe, regarding when I got bike it function very very briefly
Williamsburg
Reply #3 on: March 27, 2020, 09:39:10 am
like to add that getting tools not so easy in this period of lockdown, as well as I've been prohibited from trading for over a month , so strapped for cash, creating a period of invention and make do, although a multimeter is beyond me. if you have any tips on removing the auto advance mechanism  ( I've tried the mallet trick), would be greatly appreciated  thanks
ERC
Reply #4 on: March 27, 2020, 01:15:07 pm
You ask about finding TDC. Just bring piston up when on compression stroke until it's as high as it will go before going back down.   ERC
Williamsburg
Reply #5 on: March 27, 2020, 01:30:51 pm
Thanks, It was more of a case of not wanting to go down the road of getting the perfect reading, I've decided a method using car fuel pipe that fits nice and tight inside the spark plug. Hole, with an Allen key inside the pipe, having said that, any tips on knowing the difference between compression stroke and the other. Any help greatly appreciated.
Will
Reply #6 on: March 27, 2020, 02:05:57 pm
Will
          You, or a helper, holds a thumb over the spark plug hole. When the pressure is trying to blow your thumb out, THAT's the compression stroke.
Williamsburg
Reply #7 on: March 27, 2020, 02:08:29 pm
 Great, thanks alot.
Williamsburg
Reply #8 on: March 29, 2020, 07:35:59 am
just like to say thankyou, for all the advice received, it was greatly appreciated,  I discovered that the tappets had become over tight, something I looked at when I considered how the kick start had become stiffer. Again, thanks alot,  and take care
xenialouna
Reply #9 on: June 13, 2020, 11:36:23 am
So, If you’re relatively new to engine work and have ever pulled, or need to pull, the distributor or damper from your engine; finding Top Dead Center (TDC) on piston #1 becomes an instant priority. Finding Top Dead Center (TDC) is an essential skill for assembling and tuning engines; and is even a necessity for performing some engine diagnostic tests, such as a cylinder leak down test.
