Author Topic: Turn over,freeing pistons  (Read 4684 times)
grumbern
Reply #15 on: February 14, 2020, 05:35:00 pm
Ah, now that you say it... It's always easier to read, than to write ;)
I'm from Germany by the way. :)
cyrusb
  • Kept man
Reply #16 on: February 14, 2020, 06:20:42 pm
Your English is good, I can't speak a word of German. Nice to meet you. The international aspect of this forum is almost as fun as the motorcycles.
grumbern
Reply #17 on: February 14, 2020, 09:32:16 pm
Thanks,it's getting better little by little. It's easier to learn today, with a lot of shows, movies, videos, books etc. available through the internet, and multi-language DVDs... and forums! 8)
Only one catch: I tend to mix up British and American English quite a bit ;D
Adrian II
Reply #18 on: February 15, 2020, 11:23:10 am
A partial clue is in the spell-checker, you will find wiggly red lines appearing under British English spellings on forums (fora?) using American software. "Divided by a common language" as an Irishman once wrote...
Mudguard/Fender*
Gudgeon pin/Wrist pin
Tyre/Tire
Gearbox sprocket/Counter-shaft sprocket
Colour/Color, etc...
* I sincerely hope that there is some automotive component somewhere, maybe the mythical warble-flange bracket, for which the American English is "Gibson", in the interest of fairness, of course.
Mike flanagan
Reply #19 on: February 16, 2020, 02:53:23 am
Finally got the correct socket,thanks group.I am mainly concerned with preserving the conrods.I ordered new bearings to keep motivated,but my first attempt to turn the motor resulted in freeind the sproket nut.I got second place and a participation trophy so far,no free pistons tho...
grumbern
Reply #20 on: February 16, 2020, 12:28:05 pm
As said: Try some heat to the barrels, light force from the top of the pistons and a lot of soaking with creep oil.
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #21 on: February 22, 2020, 09:53:31 pm
Not familiar with creep oil but PB Blaster is the best penetrating oil I've found.
cyrusb
  • Kept man
Reply #22 on: February 25, 2020, 05:00:19 pm
Is the head off? If so, a pic of the bores will reveal just how rotten/seized the problem is.
Mike flanagan
Reply #23 on: February 27, 2020, 03:24:51 pm
No,not free yet.But sea foam deep creep and heat finally moved them.Dumb question,how far can i pound these lovingly til i reach the bottom of the stoke?I do not want to pound at the bottom of the stroke.They are not moving easily.
grumbern
Reply #24 on: February 27, 2020, 05:48:58 pm
About the same hight as there are fins on the barrels. The Pistons move into the case even further, but I wouldn't risk it. Once you are down there, you should be able to pull the barrels as far as the pistons have moved, put some piece of wood beneath them and continue on the pistons.
Andreas
uhu
Reply #25 on: March 15, 2020, 01:09:33 pm
What I did once (with a single), was to make a sturdy (5 mm or more) steel plate that fits over the studs, put wooden block between the plate and the pistons, an tighten down, bit by bit (don't exagerate: time and patience are half the work).
uhu
Reply #26 on: March 23, 2020, 03:26:47 pm
Classic Motorcycle december 1995
cyrusb
  • Kept man
Reply #27 on: June 08, 2020, 02:32:13 pm
Well Mike, how is it going? Im interested in how the piston freeing is going.
