After a rebuild those pushrods will probably want to settle in a bit, so you might want to keep a close eye and also
ear on them--check them every couple hundred miles or so for a awhile or if you sense an audible change in their tippity-tapping. Once you get used to their "normal" racket, you should quickly become attuned to any changes.
At some point, just for a gag, you might try adding just an ounce or two of a goop called
Lucas TB-Zinc Plus Break-In Oil Additive to whatever engine oil you're using. I saw this stuff being recommended by Ace for Iron Barrels quite a while back, started using it, and since then haven't had to adjust my tappets in nearly 10,000 miles. I check 'em, sure, but they're always just fine. Basically the Lucas goop just adds a dash of extra zinc to bring it up to those "oldtimey" pre-90s SAE grade levels of 1,500 ppm or higher that our flat tappets seem to enjoy. I'm running a cocktail of it and Mobil1 15W-50 full synthetic, which has about 1,300 ppm zinc just on its own. You can pick up the Lucas TB-Zinc at Walmart (online only for store pickup or delivery) or Amazon. Both currently charge $15.96 for 16 oz., enough for maybe 8 to 10 oil changes.
