Anyone else had Hagons fitted and seen this happen? After 2K miles the rubber bush on the offside unit is protruding from the metal eye.
The washer under the bolt head is (barely!) stopping the eye from going any further. I may fit a bigger one just to be sure but if the top and bottom mountings are out of line and the eye wants to move further to the right then restraining it might cause some binding of the shaft.
I've spoken to Hagons and they say it's not uncommon on mass-produced bikes and nothing to worry about.
I agree with Hagon's assessment: absent a damaged or improperly assembled shock, or one that's installed with the wrong bushings or something, the only reasonable explanation is that a minor discrepancy between the frame and swing arm mounting points is loading the shock and causing it to walk off the bushings. And I also agree that it's nothing to worry about.
The first thing I'd do is remove the shock and make sure the mounting points on the frame and swing arm are parallel or damn close to it. If they are, or the misalignment is very slight, refit the shock and make certain that it's not biased to one side or the other when it's bolted in place. You may have to shim it with a washer or two if it isn't. I generally install washers large enough to cover the diameter of the bushing and the shock eye which will prevent the shock from walking off its perch like yours has.
What you're seeing isn't unheard of, and it isn't the end of the world, so absent any real problems, a bent or cracked mount for example, I wouldn't worry much, there's a lot of flex in those bushings, that's why they use them so it's unlikely you'll have a binding problem even if there is some minor misalignment.
