IF the bore and rings are the issue, I recommend going +.010" bore and new +.010" piston/rings.
Let's face it, the OEM piston is a piece of crap, and so are the rings. It's a good opportunity to get that stuff out of there, put a fresh bore/hone on it to get the correct clearance, and bed in the fresh rings. There is no good reason to retain that OEM junk. Believe me.
I couldn't agree more, my bore is ok, I'll be staying standard, but a forged piston is going in, with a light hone, new valves & springs just to make sure, and I'll put it back together carefully with new gaskets, washers, etc.
I noticed that the rocker feed pipe has had a straightened out kink! so that is being replaced also.
I do not understand why the oil control ring groove has been sliced in such a manner on the OEM piston, would it not have been better to drill it like everybody else?
I am not in a great hurry to get her back on the road, I am taking my time, so I am unashamedly taking advantage of a good friend of mine who likes to polish aluminium casings, he has just done the rocker covers, and has taken away the cylinder head, I'm intrigued as to how that pans out! When the head is back, I'll give him the timing cover!
