Over the last year or so, my nice weather daily ride to work and general runabout, has been my iron barrel Bullet.
After a couple of teething problems, easily sorted, she has been very well behaved, never missing a beat, even starting first kick (when no-one is watching!). until one fateful morning.
The previous evening we got home from work as usual without anything amiss.
Next morning, she started first kick, by the time I had put on my gloves, she stalled, I tried the kick start again, NO COMPRESSION! I checked the tappets, all good, I jiggled with the de-compressor, even removed it and replaced it with a spark plug, no difference, I knelt down and stuck my ear to the inlet and exhaust tracts, couldn't hear anything untoward.
So I went to work in the car!
I looked down the plug hole with my trusty borescope, expecting the piston to be damaged somehow, all looked ok. So, without further ado, off with her head!!
I haven't touched the engine at all while I have owned her, except for general servicing, so I was quite surprised to find just about all the fasteners were not much more than finger tight! I recon I could have stripped the head off with just a pair of pliers! washers were haphazard, two fitted here and there, none elsewhere, no washers of any kind on the oil pipe banjo's, yet, there were no leaks!
The head gasket is brittle and red, I think that is where the compression has gone, there is a fair bit of carbon on the piston, but the head is quite clear, apart from a brownish coating, the bore is perfect, but glassy.
I haven't removed the valves yet.
I'll glaze bust it and fit a new piston, valves, springs, etc. all new gaskets and washers in the correct place, and tighten things correctly.
While I am waiting for the parts to arrive, I will change the gearbox sprocket for an 18 tooth and see if there is room for an 'o' ring chain.
I just find it unusual to just stop without any noticeable symptoms, so suddenly, no lack of power, no 'wheezing', no oil leaks.
I wonder if it was something I said!!
