Yesterday, we took the 500 and a misbehaving Ducati 250 to a top secret location, for some tweaking and fine tuning.
Notch by notch, I lowered the needle on the 500's carb from the richest to the leanest notch, testing the changes each time - there is also a spacer under the needle clip which I put in years ago, this can probably go now - an improvement was noted with each change of setting, however, a little lumpiness was still evident on the first bit of throttle when opening up out of corners.
I checked the slide cutaway - it was a No3. I looked in my tin of carb spares and found a No3 1/2, so I fitted that, with the needle as on the last run.
Similar work was done on the Ducati and the upshot was I was able to go into and round numerous corners in one gear higher on both machines by the time I had finished.
The irony with the 500 is although I have ridden it [but not raced it] on both track and dyno, it wasn't until I saw Ian's on board videos that I realised what was troubling him and as a result, once a 'best' carburettor setting for maximum power and good starting had been settled upon some years back, it has never been altered. Until now ...
https://www.youtube.com/watch?v=dPQihZjiNhc B.W.
