[...Snip!]
Meanwhile hang onto those AVL and cast iron Bullets as well as any Redditch RE's you might have! They ain't making any more of 'em.
Truer words were never spoken. In fact, if you've got a shed with a little space in it, I expect you could make a worse investment than mothballing some old carby Bullet in there for "later". Find some old sub-$2,000 winter bargain runner, prep it for hibernation (change all fluids including fork oil and filters, run or drain carb bowl dry, drain fuel tank, swish some motor or Marvel Mystery Oil around in it, squirt a little fogging oil or Marvel into the cylinder, remove battery, lube cables, empty a couple of cans of WD-40 or similar all over it except the saddle--use Armor All for that, slather shiny bits with Turtle Wax or similar Chrome Polish and don't bother buffing it off, set piston to top dead center and a tad to release pressure on valve springs, and just toss a cover over it [
these 2-tone ones for just $14.80 delivered ain't half bad inside or out...Mine's going on 2 years of mixed use]). Roll that Bullet out into the spring sunshine again in 10 or 15 years, and I'd be astonished if you didn't at least quadruple your investment tax-free from those eager to (re)experience the visceral and elemental pleasures of a carburetted thumper so utterly lacking in what by then will be the available crop of guaranteed character-free Nanny-State-Approved rides. Hell, here in the States in just 13 years even the last of the Iron Bellies will qualify for antique plates, which'll get you off the hook forever for inspections, some taxes and all sorts of bureaucratic impedimenta, depending on locale. That'll just be another selling point. In fact, that's a pretty good reason right now to take a close look at
any nice old pre-'94 vehicles, whatever the brand or type, if your state's not too ruthless in its restrictions on usage of antique plates. Remember:
EVERY ride is a mechanical testing event!
Seriously though, why not let those cultural and political processes of pasteurization, homogenization and pussification work for you? Stop just shouting at the clouds and stow away an old Bullet for the future!
