Took it out yesterday to give it a decent length shakedown after the R/R and PCV.
PCV has made a big difference to how the bike "feels". Amazing how much a bike is spoiled by mapping for emissions testing, also it now pulls to 5k in top on the flat (eventually), previously it would not do this.
"Rev-Xtend", seems to not work. Or more accurately occasionally work. I got to 5.5k rpm a couple of times by teasing it past at about 70% throttle in 3rd or 4th. If I just pinned the throttle I hit a limiter. I wondered if it was the canned map from H's, so pulled over and plugged in a laptop. The values at 5k+ at WOT were all minus figures (mix of -10 & -15), Changed to positive figures to see if it made a difference, it didn't. Probably shouldn't be playing with it on stock internals anyway, though I'm now a mix of annoyed and curious as to why it seems to only partially work.
After stopping for a Coffee Electric boot decided to not work, also neutral light stopped working. Started on the kick. Got home and noticed more quality wiring,
Clutch switch was trying to spit out a cable, pushing that back in sorted the electric start.
Neutral switch though appears to be a damaged wire. Bike runs fine so I'll order one next time I order service parts.
The quality of the wires on this bike seem to be a real Achilles heel. I've never actually seen wire that is so low quality before, I reckon if I went out today with the aim of buying the worst quality wire I could find it would still be better than what is used on these bikes. Rubber parts are just as bad, I replaced most of the pipes and tubes right after I bought it (with 237 miles on the clock). If they keep degrading at their current rate I can imagine in 5 years time I'll be making a loom
A nice view across Salisbury Plain yesterday morning.
