Author Topic: AVL 500 Valve seats  (Read 1727 times)
allanfox
on: May 19, 2021, 09:34:01 am
Morning, I have my 500 AVL top end off at present (long story) and found this, should the valve seats stick out so far?
Just doesn't look right and I have never seen seats that protrude so far into the combustion chamber before, not sure if bad manufacture (3000 miles) or of they have dropped (but both the same) or even if that is what an AVL head is supposed to look like, what do you think guys?
Reply #1 on: May 19, 2021, 11:51:55 am
           Welcome & be patient, my friend. You will soon get comments from guys way more expert than I. All I will say right now is "That shore don't look copacetic to me".
Reply #2 on: May 19, 2021, 12:05:36 pm
They should not protrude out into the combustion chamber like that.
It should look like this picture.
« Last Edit: May 19, 2021, 12:11:38 pm by ace.cafe »
Home of the Fireball 535 !
Bullet Whisperer
Reply #3 on: May 19, 2021, 01:17:49 pm
Cut them back, they are all too often like that - not good at all. They impair breathing and you will get increased scope for more valve lift and duration, should you want it, if you cut them back.
 B.W.
allanfox
Reply #4 on: May 19, 2021, 01:22:02 pm
Thankyou, what I had expected to see when I took my head off!
allanfox
Reply #5 on: May 19, 2021, 01:31:57 pm
 B.W.
Thankyou, does just look like sloppy manufacturing/finishing, I think I may have found Pandora's box in this engine!  :)
allanfox
Reply #6 on: May 19, 2021, 01:33:11 pm
Sure I am in the right place!  ;)
Beavs1906
Reply #7 on: May 19, 2021, 02:05:11 pm
Definitely not I would say it would create a bad hot spot  . Is there a gap behind the seat ? .
allanfox
Reply #8 on: May 19, 2021, 03:48:17 pm
Not really just not pressed in far enough and /or not cut back after fitting, sure local engine shop will be able to advise!
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #9 on: May 20, 2021, 01:38:04 am
Those may be "Madras Glowplugs", designed to assure fuel vaporization as the intake charge passes over the white-hot edges and eliminate the need for expensive spark plugs after running for awhile... ;D
That is a truly harsh thing to find inside the engine! Maybe the seat recesses weren't originally cut deep enough? Looks like a trip to a good Machine Shop is in order - post pics of the "after", OK?
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
Adrian II
Reply #10 on: May 20, 2021, 10:57:21 am
Same advice as you got on the Hitchcocks' forum, Allan?  ;)  ;D
"There is safety in a multitude of counsellors", though those words of wisdom pre-date social media!
A.
allanfox
Reply #11 on: May 20, 2021, 02:24:51 pm
Will do!
allanfox
Reply #12 on: May 20, 2021, 02:28:13 pm
A.
Both points very true, we can cast a wide net now via the forums, makes you wonder what we did before!   ;)
heloego
  • USA '12 C5, '06 ElectraX
Reply #13 on: June 05, 2021, 06:34:15 pm
Oooh, that's a sick thing from the factory. Seats need to be removed and the head cut cut deeper. Recommend new seats fer sure! Hope the rest of the engine was done better!
'12 C5 Classic
Adrian II
Reply #14 on: June 06, 2021, 10:10:50 pm
No need for new seats, just cut those back until the outer edges are flush with the surface of the combustion chamber, there's plenty of valve seat material there.
A.
