Author Topic: Which battery for Bullet STD B5 from 2019.  (Read 1156 times)
Riffhead
  • I'm only happy when I'm riding.
  • It doesn't matter, we're all going to die anyway.
on: January 12, 2022, 03:11:37 pm
Hi, I dont understand which battery's are ok for my Bullet 500 B5. In some posts here someone recommends a battery, when I look on the web site it says it's no good for my bike, I'm lost in a world of battery's. I would want to upgrade to something that's going to last a bit longer   :-[ :-[ :-[
« Last Edit: January 12, 2022, 03:17:59 pm by Riffhead »
Richard230
Reply #1 on: January 12, 2022, 10:26:47 pm
I have a small lithium battery installed in my 2011 Bullet. It is about half the size of the original battery. I wrapped it with an old inner tube to support and cushion the battery. While the battery is not designed for any Royal Enfield, after almost 10 years it is still ticking and starts the engine with authority.  :)
2018 16.6 kWh Zero S, 2009 BMW F650GS, 2020 KTM Duke 390, 2002 Yamaha FZ1
Guaire
Reply #2 on: January 12, 2022, 10:28:23 pm
It's a simple match. First, it's a 12 volt. Match the amp hours. Then match the location of the poles.
  Measure the width, length and height. Smaller is ok. Larger, no.
That's it.
something like a 12v 14 amp hour.
ACE Motors - sales & administration
Guaire
Reply #3 on: January 12, 2022, 10:29:34 pm
A good L-ion will give you plenty of power and the size issue won't exist!
JPE
Reply #4 on: January 14, 2022, 05:18:56 pm
I got mine from this company, arrived next day at a very good price. If you scroll down you can select the size you need together with battery polarity. You will get several options to fit your bike.
https://www.tayna.co.uk/Motorcycle-Batteries-S7-1.html?stype=cat
Carl Fenn
Reply #5 on: January 31, 2022, 10:31:18 am
I hate that standard battery it’s a pig to get off the rubber straps are no better especially when you want to charge, l got so peed off with it l ground a couple of nails so they push fit on the terminals and case and charge on crocks easy that way better than sodding around with those straps and bad access the standard battery is exide.
Guaire
Reply #6 on: January 31, 2022, 05:13:43 pm
True. It makes me want to switch to velcro straps, instead of the loop and hook deal.
Crispyduck
Reply #7 on: February 15, 2022, 11:12:47 am
I also changed to a lithium battery. Its much smaller and lighter and still gives more power.
Lithium also give more cranking current which helps starting.
Not sure which one fits nicely into the standard battery box though because i moved my battery into the centre and changed the housing at the same time.
Bullet 612cc (UCE carb version)
Triumph Tiger 750cc (TR7)
