The bike failed again. It started to take ages to start and when it did it would just cut out even with holding the throttle on. Got it recovered to the dealership for the 4th time.
They replaced the oxygen sensor, throttle body (with another new one), correct the valve clearance which was a bit out.
I picked it up and it was fine. Rode home.
Later that night, it started great and was fine going to work.
This morning after my shift, it started fine but did stall after about a minute of idling. Started it again and it was fine. No biggie.
When I was riding out of work in 1st gear at low speed, it was stuttering, even with the clutch out.
When I got to the main road and opened it up, it seemed to be ok.
Time will tell, I'm going to work in a bit and the bikes cold so I'll see how it's doing then. I've checked the chain tension and it's fine. Fairly new heavy duty chain too.
Ho hum, hopefully it was just a blip, but knowing this bike it probably isn't.
