No worries at all. What I was about to suggest when reusing a barrel and piston, its best to make a mark on the sleeve and the barrel so it goes back in pretty much the same position it came out. The inside dimensions of a sleeve is an oval shape and not a perfectly cylindrical shape throughout.
In the case where you are planning to use a Nikasil coating on the inside of the sleeve, there are a couple of things to take into consideration, one of them is being able to have the capability to hone the Nikasil coating. Nikasil contains silicon carbide which is also used in cutting tools and is slightly less harder than diamond. Usually to hone the Nikasil sleeve you would need diamond honing stones. It would be better to talk to the company doing the Nikasil coating and a reputed engine builder to get a clearer idea about what's involved and what their capabilities are.
The second thing to be taken into consideration is the material of the piston rings, when using an iron sleeve, chrome piston rings are used which is harder than the iron sleeve and it results in the sleeve wearing out. That is totally acceptable. After doing the Nikasil coating, it is not advisable to use the chrome piston rings on the Nikasil coating. If you ask a question such as will the engine run with chrome rings on the Nikasil sleeve, the answer is yes but the durability of the chrome rings is going to be questionable. What happens is that the chrome piston rings start pitting. To solve the issue a softer piston ring material is needed and cast iron piston rings is generally used with Nikasil coated sleeves. For the top ring you could source a Ductile Iron top ring.
Thanks again Richard. I shall ask all these questions prior to sending it away. They do have a FAQ.
Link --->
https://www.electrosil.com.au/faq.htmThey even state, the harder the rings. the better. Still, I'll call them and find out.
I'll shoot Hitchcocks a email and see what rings are supplied with their Hi Compression Forged Pistons.
This is the price comparison so far.
Find a cheaper Indian new barrel, I can only seem to find 500cc barrels. So it would need a bore out to 535cc
All in $AUD.
Indian Alloy Barrel 500cc : $307
Hi Comp Forged 535cc Piston : $333
Machine work : $200
Postage $50
Total : $890
Hitchcocks
Matched 535cc and Forged Piston Kit : $664
Postage : $50
Total : $ 714
Nikasil Coated Barrel : $450
Postage : $20
Total : $ 783
There's not much in it compared to a coated cylinder. (A carton of beer for us Aussies)
Sure I wont have a spare barrel. But the current Barrel is 535 +20. Nikasil coating can be built up to +30 thou give or take.
And my reasoning for Nikasil is service longevity. Not performance hunting/better cooling and so on.
In the past I've had Electrosil/Nikasil coated bores in 2 stroke race engines/ Enduro and Motocross. They'd go through 4 to 6 same size pistons (250 and worked 144/Big bore 125) at the time I sold the bikes and the coating was still perfect. So that's my personal experience. Different kettle of fish. But I witnessed evidence first hand.
