https://youtu.be/PeLSFTBPG3w
Andy
Interesting, on the surface it sounds exactly like what's happening with some of the Interceptors. They shut off for no reason usually when the throttle is shut as you'd do entering a turn, and then restart after the igntion has been cycled from on to off and back to on. To the best of my knowledge RE hasn't done a thing to resolve the situation with the Interceptors, so I'm curious as to what they'll do if the problem becomes more wide spread.
Part of the issue is that it's an intermittent problem and for all practical purposes impossible to duplicate in the shop. A few of the Interceptors that are afflicted with random shut offs have had every relay on the bike replaced without fixing it, though in a couple of cases the issue went away, only to resurface after several thousand miles.
There are a bunch of theories as to what's going on. While the relays are or were the prime suspect guys have replaced or in some cases eliminated everything from the ignition, clutch, kick stand and roll over switches to the kill button, all with a notable lack of success. I haven't encountered anyone that's replaced the wiring harness or ECU (yet), but it strikes me that the solution may involve exactly that.
In any event until RE admits there's a problem with some of the Interceptors and apparently the Euro 5 Himalayans we'll probably be seeing a lot more videos like that.
