I'm very pleased with all the responses. I'm getting a consensus on here that it is likely related to fuel, which makes me feel better, because I was worried it was mechanical.
Nonetheless, I'll need to take the proper steps to remove culprits. I like the plan Bilgemaster laid out, so I'll start with that. Hopefully by the end of this weekend I'll have an update to see who had an accurate guess!
Also, Seafoam was shown to me by an old boy (a fabulous mechanic by the way), who swore by it.
Regards,
Solomon
Glad I could help... hopefully. If it does turn out that those possibly SeaFoam-loosened cruds from the fuel tank gunking up the carb seem to be the culprit instead of carbon sloughing off in the combustion chamber causing valve issues, which may be fairly apparent if there's even the least bit of crapulosis seen when you peer into that float bowl, then you might consider reducing or impeding those crudlets in several ways.
One thing I've been meaning to do with my own '05, but have just never got around to, is to mount an inline fuel filter, as has been recommended in many past threads. The perennial advice found in them seems to favor filters of 10 microns filtration or better, though my hunch is that most ANY added filter would be preferable to none. Hitchcocks does offer a couple of options with unspecified filtrations, a fancy chrome one with a cleanseable reusable filter and a single-use one, both shown here:
https://accessories.hitchcocksmotorcycles.com/Amal-Carburettors/Petrol-Pipe-Fittings?ext=F&search=Fuel+filter+inline. Obviously, other inline filter options abound online or at your local parts joints or Wallyworld. Some choices specify their filtration specs (
i.e., 10 or 40 or 100 microns seem common--the smaller the number the better the filtration), but most don't. Perhaps someone else here can recommend a specific "good one" for our carburetted "Iron Bellies" with a link for online purchase.
It turns out you probably already
have an inline fuel filter incorporated at the base of your fuel petcock that you can rinse out. Mine's shown in place on the tank and then disassembled after cleaning in the attached photos. With the fuel tap set to "Off", you just unscrew its base with a 13mm wrench/spanner, taking care to set aside its rubbery round sealing gasket, go to town with some spray carb cleaner and maybe a little screwdriver or brush for any stubborn chunklets, and just button it all back up and test for leakage.
One trick used by me and many of my fellow amphibian Amphicar motorists in addition to inline fuel filters is to slap a big magnet or two onto the bottoms of our steel fuel tanks, which are also obviously quite prone to rusting given our bizarre predilection for aquatic motoring. These magnets will attract and hold those iron oxides quite firmly in the fuel tank, keeping them from finding their way into the fuel lines until such time as the tanks can be cleaned out or resealed from time to time. I use big old fashioned black ones for the Amphicar, but a handful of these rare earth 5/16" diameter type (
https://www.harborfreight.com/10-piece-rare-earth-magnets-67488.html) popped strategically around the bottom of your fuel tank would probably work nicely and be inobtrusive. I also pop those little ones, sometimes a couple, onto the outer heads of all my various vehicles' oil drain bolts, including the Bullet's, to magnetize them throughout and thereby catch and trap the odd ferrous bits floating by within until the next oil change.
Obviously, if your tank is really crusty within, unlike mine, especially if you use fuel with added water-attracting ethanol, which I don't, then cleaning out and possibly sealing that fuel tank might be a sensible long-term solution, and there is much guidance to be found on this in this Forum's archives--everything from raiding the pantry for white vinegar rinses to multi-part wonder potion stripping and sealing kits.
In terms of avoiding fuel tank rusting in the first place, it is always advisable to keep the tank fairly full. This reduces the amount of air within with its water vapor that can condense, drift to the bottom and commence wreaking havoc. This is greatly exacerbated if ethanol-containing fuel is used, since that ethanol eagerly binds up with that water into a nice cloggy caustic snot. In really advanced long-term cases, such as I discovered in the carb of a little used fixer-upper outboard I'd bought, that snot will eventually fossilize into something resembling British Demerara sugar or that "Sugar in the Raw" stuff they have at Starbucks.
