Previously, under a different thread title, I detailed electric start problems that appeared to be related to neutral position. I seemed to have solved the problem, without knowing how, only to have it rear its ugly head once again! This time I tried starting it with the float charger attached, and it started up every time. Once warm, it started without the charger, but after getting cool, it would not. At this point, it would also start electrically after a previous kick start. I tested the battery, which showed a full charge, but was marginally good under load. I installed a new battery. Thereafter, it started right up - until I left it overnight, and then the same conditions applied. I tested the battery in case of parasitic drain, and could find no indication of it.
As previously posted, I have replaced the neutral position sensor and the clutch lever switch. The bike will not start with the clutch pulled-in unless it will also start with it not in. Now, the rocking back and forth as previously mentioned does not seem to do the trick. But, kick start, run it a minute or two. Turn it off, and it will start electrically until it is allowed to cool down for about 5 minutes. I can hear the fuel pump spooling up every time I turn-on the key. I have electrically tested every component in the starting circuit without finding any defects. When I press the starter button and get no response, the neutral light and the headlight dim just a little.
I am beginning to suspect the starter switch/button, but this is more out of desperation than deduction. I don't understand why the electric start works after a previous kick start, or within a couple of minutes of a previous electrical start, but not otherwise. The kick start is smooth and almost effortless - it fires the bike right up.
I have abandoned hubris and the claim of credit for the previous fix that has quickly become an "unfix". I am open to humility and modesty in exchange for a fix that won't unfix itself. Ideas???
And - 2009 Bullet 500 (G5) - otherwise runs like a dream...
