Hi guys
Same issue with my new 2021 EU5 Continental GT 650... it did it in the very same day I went to the dealer to pick it up! I tought it should be down to the bike being in the break-in period, but with all these comments here in the forum, I guess it´s not.
Still with only 200km (124 miles for you UK folks out there
) it has happened 2 more times, always under the same circunstances. Small blips in the throttle at low revs, the rpm drops to 800 and if the blip occurs when the rpm is in that low range and it stalls. It always happens during very low speed manouvers, like in heavy traffic when you are squeezing through cars. It makes sense, because that´s when you´re giving small throttle inputs.
It seems it has to do with fuel managment by the ecu and not with any faulty sensor.
I guess I will wait for the post break-in first service at 500km (310 miles) to inquiry the dealer if they are aware of this issue and if there are more complaints from other owners or even a service bulletin issued by Royal Enfield regarding this issue.
I´ll be following this post and reply when the time comes.
