I've got a good story for the "electrical nightmare" crowd here.
My bike has always had an occasional "stumble" that was unpredictable, and sometimes affected idle and was sometimes felt at low speed running, but was very intermittent.
I had always assumed there was a carb issue that I couldn't track down, like some dirt or something that might occasionally infect the carb, and then move thru.
However, I just recently installed my new tachometer last weekend, and I was running the bike yesterday to warm it up, and I noticed that when it stumbled, the tach needle jumped around wildly, and then settled back to normal again, and then when it stumbled again a few seconds later, the tach needle went wild again.
At that point, I knew it was something electrical.
So, searching and testing, I had the cap off the distributor, to see if I could track something down inside there.(BTW, I have the Boyer Mk3 ignition). But, try as I may, I couldn't find anything, and every time I ran the bike to see if the problem was still occurring, it ran perfectly, with no stumbles, and the tach needle was steady as she goes.
So, I decided that I couldn't find it and would hope for the best, and put the distributor cap back on to "button her up". Then I decided to go on with my warming up of the bike, so I kickstarted it, and it had trouble kickstarting, and then when it did get started, the stumbling was back and the tach needle jumping around again.
Well, the only thing that changed since it had been running perfectly a minute ago, was that I put the plastic distributor cap back on. So, I took it off again, and re-started the bike. Perfect running, no tach jumping. Put the cap back on, Problem comes back.
This is a PLASTIC cap! I have no idea why it is causing a problem, and it's not pushing the wires around because I tried checking that.
Soooo, I go in the house and get my spare other plastic distributor cap, and put that one on the bike, and it runs perfect!
No problems now.
Why in the world a particular plastic distributor cap with no electrical function would do this to the bike, I have no idea. And why an identical replacement works just fine, I have no idea.
But I can tell you that in almost 40 years of mechanic work, I've never seen anything like it.
