Nothing to do with the operator in my case; I find that quite offensive. Points are easy enough to look after. I first started working on engines using them in about 1969 and I still have a "dwell meter" in my tool cupboard and I have a 1930 engine that still uses points - I've just got it going after many years of it sitting idle. I did grease the cam....
What makes points fail is poor/faulty quality condensers. They either work well, or fail, then the points rapidly burn. I just grew tired of replacing them. NOT on an Enfield, btw - mine is an iron engine but with factory TCI, so no distributor fitted. I'm not sorry it doesn't have one. I posted earlier how I was having to buy two or three condensers at a time for my little car in the hope of finding one that worked out of the box. Modern ones seem to be less reliable than in the past - possibly because of their place of origin.
Some years ago I built my own competition car from the chassis up, including all the wiring. The engine was re-manufactured (as back to factory specifications or better, not just reconditioned). Having jumped through all the UK/EU rules book hoops to get it road legal (it passed the Single Vehicle Approval Test first time, not many do) I took it out for it's first road run, did about 100 miles. The following day it wouldn't start. The points had blackened due to a failed (brand new) condenser. I went through ten years of similar points failures, ALL related to poor quality condensers, before switching to an Aldon/Pertronix Ignitor, which is an electronic trigger which replaces the points altogether and needs no condenser. The breakdowns were cured forever, it was more or less fit and forget, as per in all modern cars.
I've had three other occasions where condenser failures have caused me breakdowns. Once in a newly serviced Nissan (that one was really difficult because we had a caravan, three kids and a dog involved - coming back from a holiday. Another was in my Ford and another in a Vauxhall/Opel.
About fifteen years ago I drove the car 95 miles to compete in an off-road trial. I met another competitor who had built the same type of car as mine, with the same engine. His car arrived on a trailer. He came over to compare notes and in discussion told me how unreliable electronic ignition was, in his opinion. An hour later his engine cut out on a hill section. After I'd finished my section I went over to offer any assistance. His points had burned out! I offered him the points setup I carried in my spares packup but unfortunately it was a later type than he used with a different design and it wouldn't fit his distributor. That was the end of his day because he had no other spares with him.
I've never had a failure of an electronic ignition system. My son's Honda Integra did have a temporary failure a few days ago but this was caused by a hose clip tail contacting wiring to the coil, wearing through the insulation and shorting it out. He was back on the road in half an hour.
