Hey all,
I've read it on here over and over again to not use the throttle at all when starting your bike. When my bike is cold, even if I prime it and use the choke then kick it over, it'll idle for a few seconds then die. If I keep kicking it over it'll work after 3 or 4 of these 'idle then die' sequences. A fool-proof way to get it started first try for me is prime it, choke to enrich, kick it over, then once it's ticking give it a tiny crank of throttle. Works like a charm.
I don't want to be doing anything to harm/cause a problem in my bike. I remember reading before that using throttle too soon can flood (something?).
Thanks in advance for any help... also, did the first DIY oil change last night... just engine oil so far but got it all finished without recreating the Exxon Valdez and without shooting my eye out with the red rider filter spring.
