My new Enfield
February 11, 2016, 09:30:07 am
Author Topic: Kickstart Pawl Replacement  (Read 2129 times)
Bankerdanny
« on: February 05, 2008, 03:59:54 pm »
So last Fall I ordered the sintered kickstart pawl as my kickstart seems to be slipping (It's not the lever, I checked that first).
The text says "installs in about 30-minutes" OK, but how?
I have the spiral bound service manual, but frankly it is so limited in its coverage that it's like the Readers Digest condensed version of a repair manual.
I have followed the link provided by several people to the Enfield Workshop manual at Tripod, but it's not really any more helpful. Nice expanded view, but that really isn't a substitute for a good step-by-step description.
Can anybody describe the install, or better yet, point me to a more comprehensive repair manual?
 I am really quite adept at this kind of stuff, but I don't have a garage to work in, so don't have the luxury of figuring it out on my own, I need to get in and get out in a day, can't leave the tranny opened up over night.
Thanks
Endeavor To Persevere
  • Administrator
Re: Kickstart Pawl Replacement
« Reply #1 on: February 05, 2008, 04:53:50 pm »
4 speed or 5 speed?
President
Classic Motorworks
www.classicmotorworks.com
www.cyclesidecars.com
Bankerdanny
« Reply #2 on: February 05, 2008, 05:02:56 pm »
'02 500Es 4-speed.
I just ordered the Snidal CD-ROM, so maybe that will help.
Thanks Kevin.
Are you guys at the Chicago motorcycle show this weekend?
  • Administrator
« Reply #3 on: February 05, 2008, 05:25:30 pm »
1. Remove the outer transmission cover
2. Remove the shift mechanism paying strict attention to the order in which parts are removed
3. Remove inner-transmission cover. Note that the shaft which protrudes frmo the cover has a LEFT HAND thread.
4. When you remove the outer transmission cover, look on the inside and you will see the pawl.
5. Pull it out with a pliers making sure not to lose the plunger and spring.
6. Dig out any of the old grease which may have hardened
7. Re-assemble
8. Re-adjust the shift ratchet mechanism
President
Classic Motorworks
Bankerdanny
« Reply #4 on: March 10, 2008, 07:30:09 pm »
bump
