Author Topic: anyone know what these wires are?  (Read 5381 times)
DanKearney
Reply #15 on: August 29, 2013, 01:27:01 am
The "green ended" one is the ECU check wire - ground it, turn on the key - get trouble codes. the other is the ALDL (Assembly Line Data Link) connector - this is where the ECU's programme is dumped into the bike on the line - and where the diagnostic tool interfaces with the ECU.
How does it display the codes?  As series of lights flashing, etc?  If so, is there a key chart somewhere that we owners could use for troubleshooting?
Cheers,
Dan K.
t120rbullet
Reply #16 on: August 29, 2013, 02:52:46 am
MIL BLINK CONTENT
Engine will start but not perform to its potential. MIL will glow continuous
LONG 0 SHORT 6 Throttle Position Sensor (TPS) circuit malfunctioning
LONG 0 SHORT 9 Manifold Absolute Pressure (MAP) circuit malfunctioning
LONG 1 SHORT 1 Engine oil Temperature (TE) circuit malfunctioning
LONG 1 SHORT 7 O2 Sensor circuit malfunctioning
LONG 4 SHORT 5 O2 Sensor heater circuit malfunctioning
Engine will NOT Start but will crank. MIL will glow continuous
LONG 1 SHORT 5 Rollover Sensor circuit malfunctioning
LONG 3 SHORT 3 Injector circuit malfunctioning
LONG 3 SHORT 7 Ignition Coil circuit malfunctioning
LONG 4 SHORT 1 Fuel Pump circuit malfunctioning
LONG 6 SHORT 6 Crankshaft position circuit malfunctioning
1972 FLH "Sambo"
2023 Guzzi V7 Special "BOB"
Roeland
Reply #17 on: August 29, 2013, 02:18:34 pm
Hi,
Is there any way to re-set the blink content of the ECU? It seems the ECU stores all error codes even after everything is working perfectly again?
Thanks
Roeland
Reply #18 on: August 29, 2013, 02:47:49 pm
Most ECUs, cars and bikes, you just disconnect the battery for a good 15-20 minutes and that will usually reset the codes.
DanKearney
Reply #19 on: August 29, 2013, 03:00:38 pm
MIL BLINK CONTENT
Thanks!  This will now be squirreled away in my new "Little Book of Enfield Knowledge".
Cheers,
Dan K.
Desi Bike
Reply #20 on: August 30, 2013, 11:38:06 am
Dan, I printed the codes on a card, laminated it and tucked it into the fuse box.
میں نہیں چاہتا کہ ایک اچار
Reply #21 on: August 30, 2013, 04:39:21 pm
Genius!!!
Reply #22 on: September 02, 2013, 07:29:01 pm
Not the case with the UCE. It stores the codes until they are erased with the Factory code scanner - which no one has. The ECU will display the codes set from last to first with no repeats. Also a code "41" is USUALLY a rotten ground in the system - NOT a bad injector. It's a pretty common code to come up .....
Reply #23 on: September 02, 2013, 09:04:37 pm
   I can attest to that !  ;D    And as was explained to me ^^^^  Before I hung myself from a rafter with a motorcycle chain !  If you have a sensor disconnected, with key and ignition on.... it will through and store a code.  I did this when rewiring the bike and testing.  ... But even though the code is stored, the MIL light will go out when corrected.  So bear that in mind when trouble shooting.... if you start pulling sensor plugs and such.  Don't get alarmed.... just remember what you pulled and whether the key was on or not.
