solo seat after
May 25, 2016, 08:10:03 am
Author Topic: Crank Vent Hoses!  (Read 1221 times)
sewerman
Crank Vent Hoses!
« on: February 19, 2008, 11:19:48 am »
I tend to ride my 04 Bullet cafe hard which really gets the crank pressure up.  The other day both hoses let loose and what a mess it caused!  Fortunetly I was just going back to my house when it happened.  Both of the original hose clamps were shot, I could easily bend them with my fingers.  I replaced them with quality clamps and now there is no problem.  My bullet only has 3k on it so they were not that old.  So it might be a good idea for all you fellow Bulleteers to replace yours before they "Go South"!  On another note I just replaced the original battery and the coil( with the Bosch unit) and what a difference it made.  Definetly worth the $'s and effort. :o
fredgold52
  • Macomb, IL Flatlands Rule
Re: Crank Vent Hoses!
« Reply #1 on: February 20, 2008, 01:40:13 pm »
Sounds like a good thing to do while the hoses are off the bike being re-routed into a more effective configuration.
Good heads up.  Thanks
