Author Topic: Lowered C5 pic.  (Read 7123 times)
snowkid03
Reply #15 on: April 01, 2012, 11:26:28 am
any tips on lowering my g5 that wont void the warranty?  im short. 5'5... and on the balls of my feet- i like to be low!
Reply #16 on: April 01, 2012, 07:23:51 pm
There are some lower seats available or the G-5. The Electra Low Seat will fit. It's available on Nfield Gear's website above on this site. You could also take your seat to an upholstery shop that should be able to shave the foam down and just pull the existing cover back down on the seat. I have done this myself on a couple of seats. If your handy with such things, you could probably handle it yourself. All it takes is an electric knife to cut the foam down and a sanding block to smooth the foam and some spray contact cement for the foam to reattach it.
You could go with shorter shocks, but I wouldn't recommend them. They'll change the handling in a "not" good direction. Much slower heavier steering, unless you change the front wheel to match, ie, go to an 18" wheel.
You reach the ground about like I do looking at your picture on the other thread. I've learned to deal with it. Actually this one is much better than my previous bike. A Triumph Scrambler that was taller and 100 lbs heavier! This one has been pretty easy.
« Last Edit: April 01, 2012, 07:32:50 pm by barenekd »
GlennF
Reply #17 on: April 01, 2012, 11:40:18 pm
snowkid ... I just replaced the stock dual seat on my B5 (never have a pillion anyway) with an unsprung trials style solo seat and a chrome rack.
BRADEY
Reply #18 on: April 02, 2012, 07:20:36 am
Bringing in the rear fender to close to the tyre has its own perils,
this has resulted in damage of wiring loom that goes very close
to the rear fender on the side facing the tire. This has resulted in
short circuits and damages to wiring which is expensive.......please
ensure that is not the case on your bike.
snowkid03
Reply #19 on: April 02, 2012, 02:01:06 pm
thanks bare, glenn and bradley...
bare- i was looking at the electra low, but its got too much of a modern style for me- maybe when i get better at riding if height is still an issue for me...  i also kinda want a brown seat :)  prob. my cheapest bet for right now would be to just get this seat shaved down an inch or two- the nice thing about us ladies riding is we only need a little padding in the seat cause our booties provide the rest of the padding :)  i road bike sometimes less is better!
glenn- is that the seat off of nfield gear- the classic comfort?  i was looking at that one because i like the minimalist design.  when putting it on did you have to fill holes in the rear fender after removing the bracket for the original seat?  does it change your positioning on the bike by sliding you back a few inches?  i like how my arms comfortably reach the handles (and how the clutch/break fit my small hands unlike other bikes where it is a stretch to the grips!)
and brad: what are you talking about with the fender being lower?  i know the seat holds it, but that isn't its only support is it?
i wish it was light out so i could go drink my coffee and look at my new toy :)
-kelli
GlennF
Reply #20 on: April 02, 2012, 02:18:32 pm
Its actually a generic 350 seat I imported from india.  The rear mounts onto the shock bolt and the front didn't really need a mount, so I just padded it with some old hose.
The nfield classic looks similar but doesnt list a G5. Hitchcocks in the UK also have a classy looking trials seat.
My seat is quite long so you can sit forward or back - its up to you. The B5 does not have fender holes the stock seat used to attach to the side rails.
Note when looking for parts, your G5 uses a frame based on the older AVL/Electra models, not the iron bullets.
snowkid03
Reply #21 on: April 02, 2012, 02:29:04 pm
did it drop the height for you? how does one go about importing something from india?
GlennF
Reply #22 on: April 02, 2012, 03:42:28 pm
Yeah, by about 2".
There are numerous online stores selling Enfield parts out of india. Simply search the web or ebay for enfeild parts. You generally pay by paypal.
The Indian parts suppliers are very cheap, even after freight.  However personally I only use them for accessories and non mechanical items like the seat I bought.  I am.not sure I would trust engine parts from an Indian online store.
GSS
Reply #23 on: April 02, 2012, 03:51:50 pm
Kelli,
Welcome to the group!  Bulletwala in India has been very reliable for parts as have Hitchcocks from UK. However 75% of my purchases end up being from Nfieldgear. All 3 are reliable, and prices can be very similar if you factor in shipping.
GSS
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
Reply #24 on: April 03, 2012, 12:13:45 am
I guess I should add that almost all of the aftermarket parts don't seem to just "fall into place" when they are being installed.
New bolt holes or enlarging or elongating existing bolt holes seems to be required for almost all of the things I've added to my bike.
GSS
Reply #25 on: April 03, 2012, 06:41:59 pm
+1.  Even RE "genuine parts" almost always need some coaxing and bending.
2019 Himalayan Snow
Previous REs:
