I think to make Scottie's suggestion work you just need to curve the hose to follow the line of the pinstripes on the front of the tank. I like the idea except for having an exposed plastic tube along the outside of the tank. That doesn't seem like something that would fare well in an accident. Scott
Who needs a fuel light when you can do this mod? I'm thinking of doing this to the Blackhawk.Scottie
... Of course, one would have to remember to look every once in a while to see if the gas was low--less directly informative than the engine coughing that occurs when one needs to flip a petcock to the reserve position.
The fuel is what cools the fuel pump in fuel injected vehicles (including the RE).If the tank runs dry the pump can overheat and fail.
