We have low carbon build-up with the Fireball.
The worst offender is poor combustion efficiency, and a slow-moving exhaust tract, which are both present quite plainly in the normal Bullet.
Plus, people run Bullets rich, to try to combat excessive heat, and it leads to carbon all over the inside.
And low speed riding on small throttle-openings doesn't ever blow anything out, either.
Some Sea Foam or something like that can help with these things.
The Fireball probably won't need any decarbonizing until it's ready to have a valve job anyway.
