Final Config..(maybe)
May 25, 2016, 04:20:09 am
Author Topic: Fuel Injector & Valve Cleaner / Lube for Motorcycle ?  (Read 7613 times)
SSR
Re: Fuel Injector & Valve Cleaner / Lube for Motorcycle ?
« Reply #15 on: February 25, 2011, 05:22:34 am »
Anyone ever used OWS(germany) additive products?
ROVERMAN
« Reply #16 on: February 25, 2011, 07:36:08 am »
Techron fuel additive is a life saver.When i was working at a VW dealer in the 1980's it was recommended by Volkswagen for removing intake valve deposits.I have seen deposits on intake valves that looked like a primordial forest using a borescope completely eradicated with one tank treatment,it is the cat's meow.
Robert & REnfield.
ROVERMAN
« Reply #17 on: February 25, 2011, 07:45:10 am »
Oop's, i must be going senile.I now work with direct injection gas engines,and guess what?Techron is back in the picture for cleaning carboned-up injectors.
bob bezin
  • I ride therefore I am.
« Reply #18 on: February 25, 2011, 10:00:36 am »
how does that compair to sea foam?
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
« Reply #19 on: February 25, 2011, 10:32:35 am »
ROVERMAN
« Reply #20 on: February 25, 2011, 10:48:14 am »
Thanks Singh,that about sum's it up.
« Reply #21 on: February 25, 2011, 11:37:18 am »
Isn't it also a selling point with their fuel..chevron gas with techron in it??
« Reply #22 on: February 25, 2011, 12:03:00 pm »
Randhawa Ji:
Sat Sree Akaal.  Below is an Indian car website that has reviewed OWS 360 fuel additive in comparison to others available in India.  Can you buy it in your home town ?  If so, copy the MSDS sheet or the list of its ingredients from the Can.  Then we can compare it to what is sold in US.
http://www.tatasafariclub.com/node/246/image_gallery
Tri750
  • Big Al
« Reply #23 on: February 25, 2011, 12:03:45 pm »
I cant comment on Sea Foam, never used it.
Chevron does use the Techron (was known as Techrolene) in their gas but its a small amount for everyday use. The concentrated stuff is for engines where there IS  a problem.
Shell has a simular additive as does Unocal.
Using the Costco Techron is probably good too but with the lower amount of active ingredient, youll have to do the math on what is the best buy.  We use it on bikes that have a problem or as a every few months "booster shot".
Again, ours is one ounce per gallon, 15.00 per 20 ounce bottle.
Current bikes:
'71 BMW R75/5 racer
'73 Kaw Z1 racer
'77 Tri 750 Bonneville
'99 BMW R1100RT
« Reply #24 on: February 25, 2011, 12:34:22 pm »
Bob:
The ingredients in Sea Foam are very different from those of Techron Concentrate Plus Fuel Additive.
Australian Chevron website states that Techron contains polybutene amines (PBA) and polyether amines (PEA).  There was no mention of what else it contains.  Assuming it is a mixture of several PBA and PEA compounds, it will act like a strong organic solvent.  Need more information on the exact composition to fully assess its functions.
http://www.chevron.com/products/prodserv/additives/tcp.aspx
Sea Foam however has 3 different ingredients, each doing different thing - it is a multi purpose additive - 1) It acts as solvent.  2) it acts as lubricant.  3) It removes water.  I have its composition listed in the MSDS thread in Tech Tips of the Forum.
« Last Edit: February 25, 2011, 01:02:32 pm by singhg5 »
SSR
« Reply #25 on: February 26, 2011, 05:04:48 am »
Sat Sree Akaal Singh Ji.
So far I have managed to locate three system cleaner available in my town.
A. OWS(Germany) for two wheelers- No info on content.
B. Wuerth(Germany) Petrol Additive-
1. Low boiling point hydrogen treated naptha
2. Propane-2-ol
3. kerosine
4. Hydrocarbylamine
5. Phenol, isobutylented
6. 2-(2-heptadec-8-enyl-2-imidazolin-1-yl)ethanol
7. (Z)-N-methyl-n-(1-oxo-9-octadecenyl)glycine
8. Napthalene
C. Cyclo(USA)- Max 44 total system cleaner - Contents
1.     Fuel oil, no. 2
2.   Xylene (mixed isomers)
3.   Ethylbenzene
4.   Naphthalene
5.   Polymer Amine Blend
What do you think which one sounds more promising?
nigelogston@gmail.com
« Reply #26 on: February 26, 2011, 05:27:46 am »
I am jumping into this thread late and know absolutely nothng about engine fuel additives, but I had wondered in an earler thread whether the alcohol content variation in gasoline from region to region may account for some of the variability in performance (both speed and mileage) we see from owners on these threads/  SB's comment above on this thread regardign the potential to "fool" the oxygen sensors make we wonder that again.  Thoughts?    Nigel
« Reply #27 on: February 26, 2011, 07:55:39 am »
YES! The fuel blend will definitely affect mileage and performance - more ethanol - less mileage, percent for percent almost. It's exacerbated on a ONE cylinder engine because you FEEL every firing cycle, too .... one or two lean hiccups in a row and you are going "WTF????" ................
« Reply #28 on: February 26, 2011, 08:36:24 am »
I think alcohol has about half the energy of gasoline when you burn it.  It's a very clean burning fuel but if you run a fuel like E-85 (85% ethanol, 15% gas) you need things like bigger injectors or carbs to deliver the fuel the engine needs and you get much less power for the same displacement.
« Reply #29 on: February 26, 2011, 08:50:10 am »
If one is forced to tank up with 15% ethanol, would a little can of octane enhancer help? Nigel   .( And   Is that legal where they make you buy gasahol?)
