May 31, 2016, 02:51:33 am
Author Topic: Problem with G5; no electric start then later engine cutting out and backfiring  (Read 1244 times)
Chris-G5
I think I may have jinxed myself!  ??? I had posted a couple of days ago that I had not had any problems with my G5 except a loose wire to the fuel pump in '09, also forgot a bad low fuel sensor in '10. Now today I have a problem while riding on this beautiful 60+ degree day. On my last stop when I went to start the bike the electric start did nothing. So I folded out the kicker and it started right up on one kick. I rode around 15 or so miles, on the way home, then the engine started cutting out bad and backfired quite a bit. I was around 4 miles from home. I was able to keep going sputtering and backfiring till I made home. It seemed like it ran better at high RPMs but still cutting out and backfiring off and on all the way home. At home  I turned it off then turned ignition and the kill switch on again. The MIL and fuel pump did not come on. I tried again and the MIL and fuel pump came on and shut off like normal but the electric start did nothing and couldn't start it with the kicker.  I turned off the kill switch and ignition. Later I turned them both on again and neither the fuel pump nor the MIL came on. The neutral light was on but the blinkers did not work either. So I decided to wash the bike, as it was super dirty from riding through all the water from the melting snow, before I investigated more. After washing the bike the fuel pump and MIL came on but no electric start. Kick started it and it fired up sounding pretty much normal and reving pretty good. I let it idle for a bit then the idle lowered and it sputtered out. It has been the same since. I checked the starter relay by ohming the coil. Got 3.3 ohms. Then checked if the starter relay was closing by measuring the voltage across the relay switch, which was low around 9 volts. The voltage reading should have dropped to zero when the relay closed, by pushing the start button, but it did not. You can hear a faint click when the start button is pushed and the neutral light dims. Checked the battery it was low, around 9 volts. I put it on a tender and later went to check it and the tender check battery light was on. So battery is probably bad, but that doesn't explain the bike cutting out, backfiring, and now dying at idle. I haven't tried riding it. I'm thinking some sort of electrical problem. Any thoughts?
Chris
Chris-G5
Just went out to check it again because I put the battery back on the tender. The tender check battery light was on again. I unhooked tender and turn the bike on and it barely started with the electric start. Check the voltage at battery while running it was around 9.6 volts. Seemed to be idling fine. Continued to check voltage while idling and it was dropping. When the voltage approached 7 the idle went down and the bike died when the voltage dropped below 7. Could the battery be the whole problem or maybe the alternator?
r80rt
  • C5 Pilot
I think it's just a bad battery.
Iron Butt Association
olhogrider
  • Black C5
  • 2012 C5
What he said. I would hook up jumper cables to  a car battery and see how everything functions. I think the alternator is trying to revive a dead/broken battery when it should be powering your electrical system. Even your Tender is trying to tell you something.
Chris-G5
Yeah I think the battery is most likely bad or getting there. I have been meaning to replace it with a new sealed battery. Although it does seem that the alternator should power the electrical system even if the battery were dead. Which would mean either the alternator or the regulator is bad. The regulator is built in with the rectifier. There is a rectifier regulator unit test in the service manual. It says to check voltage at battery with engine a 3000 RPMs and there should be between 12.2 and 13.5 volts. I guess I'll try replacing the battery. I hope I can find one in town and not have to order one.
Chris-G5
I just tried the rectifier regulator unit test and the most I was reading was in the high 8 volt range. Hard to tell what RPM I was at without a tach but I was reving it pretty high. So I am thinking the regulator is bad. @ Scooterbob, what do you think?, has there been previous problems with bad regulators or charging coils? This is an early G5, bought May '09 from Interstate Motorcycles. Bike built Jan. '09
r80rt
  • C5 Pilot
Maybe you ned a fully charged battery to do a proper test?
gashousegorilla
Yea, what he said. Disconnect the battery from the bike, take it out and see if it will take and hold a charge on the bench. And as Dan suggested , if you don't have another, take you car battery out, hook t up with jumper cables, then do your tests. CAREFULLY with the cables, don"t short anything out, there is sensitive electronics on the bike.
UncleErnie
Numero one-o;  iof you have to use a car battery, DO NOT START THE CAR.
When a dealer puts a bike on the floor, he puts a barry in it.  and the battery sits with the bike.  So you come along and buy the bike and- Hey- this thing domne't work!  Well hurry up and get a charge on that battery because the customer is coming to pick it up.
A fast charge is not good for a battery.  Batteries love slow.
Plus- when's the last time you cheked the fluid level?
Take your old battery in to any bike shop where they can get you a decent Yuasa and re-cycle the old battery for you.  They may even have it in stock, but it wi;ll take about 5 hours to charge.  If you have a TENDER at hame, you can have them put acid in it and take it home to charge.  On a battery tender.
Run what ya brung
gashousegorilla
Chris, you sort of answered your own question here.The alternator on a bike,  usually will not be strong enough to power a bike at idle.There for it will die out at idle, ...... If your battery is bad, it will not take a charge or hold a charge even at or above 3000 rpm's.  The eratic behaviour your describing, sounds like a bad battery. You MUST have a good one to check the out put of the charging system. Once you have a good battery hooked up, hook up your multi meter and rev the engine up pretty good and watch the meter.
Chris-G5
Alright, alright!  ;D I'm going to get a new battery tomorrow. Hope that fixes it! The weather is too nice not to be riding.
prof_stack
A new sealed or gel battery is the way to go.  Did you keep the OEM battery on the 'tender whenever the G5 sat?
Chris-G5
Not all the time
clubman
Chris
I had something similar to this last summer when I spluttered home on a flat battery. In my case it was duff wiring rather than a duff battery as in the wiring was wrong from the day it left the factory allowing it to carry on running directly off the battery with all fuses blown and no charging. Once the battery is flat it stops running. Leave it half an hour and it recharges itself just enough to run a bit longer but then it will stop again as there isn't enough power to run the fuel pump. That's what was happening to you too.
Chris-G5
So what exactly was the fix for your G5? Just replacing the fuses? Changing the wiring?
Thanks, Chris
« Last Edit: February 14, 2011, 08:21:12 am by Chris-G5 »
