Author Topic: New Heat Shield for the Upswept Muffler  (Read 5663 times)
robbw
Reply #15 on: February 16, 2011, 04:13:57 am
Yes, same piece and my pant legs are already grateful.
Reply #16 on: February 16, 2011, 08:45:34 pm
I think I found that part on the web for anyone who needs it:
http://www.lowbrowcustoms.com/index.php?l=product_detail&p=945
prof_stack
Reply #17 on: February 16, 2011, 11:51:59 pm
Looks like the same part.  But it is marked as out of stock.  If a person wants it now, just call Bent Bike Motorcyce Salvage  (425) 776-9157 and they will ship it.  I just called them to verify.
GlennF
Reply #18 on: August 22, 2011, 04:50:04 am
Interesting. I was thinking of fitting an 18" Samson heat shield that I can get here in Australia for around the same price of importing a 12" one. Might even drill a hole in the center and use one of the original mounts and screw to add some center support.
One question. What was the reason for changing the foot peg position ?
prof_stack
Reply #19 on: August 22, 2011, 05:19:33 am
I wanted to get the peg further under me rather.  I now have them in the center position where they will stay.
In a sense I was looking for a seating position more like my previous Buell xb9s.  That will not work with the C5 without installing rearsets of some type.  But the new Guzzi Breva has the seating/riding position that I was looking for all the time.
GlennF
Reply #20 on: August 25, 2011, 11:35:35 pm
OK, I fitted the 18" Samson heat shield and it fits reasonably well, It covers the entire straight section of the pipe.
Of course the real problem area is just forward of the upward bend under the swingarm bolt area, as that is both the hottest part of the pipe (because of the bend restricting flow)  and also where your leg is most likely to touch it when sitting astride the bike :D However extra cannot hurt and it actually looks good.
In my case I just bolted the shield on over the top of the old screw mounts. You would get a neater fit by grinding off/removing the old mounts however unless you are building a show bike it really isn't worth the effort. Mounting was a 5 minute job.
Overall for a 5 minute job it makes the bike safer and more practical to ride and also looks better than the stock shield. Well worth doing.
http://www.samsonusa.com/H-113.html
« Last Edit: August 26, 2011, 12:16:12 am by GlennF »
prof_stack
Reply #21 on: August 26, 2011, 02:08:17 am
+1   Very nice!
